WiFi Thermostat
This post has 10 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Oct 13 2013 9:37 PM
Does anyone have a WiFi thermostat? I am looking for one.
There is pretty much only one choice in the UK - Heatmiser. I do not mind buying from outside the UK - any options?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 13 2013 10:30 PM
Nest ?
BeoNut since '75
Pushkin
Posts 46
Pushkin replied on Sun, Oct 13 2013 10:44 PM
Yes Nest - US product designed for the US but I know a number of people who use in the UK - as far as I am aware the only stylish thermostats in existence - am installing some shortly.
Chris Harrison
Peak District
Posts 381
Nest thermostat not available in the UK at the moment.
Nest protect - smoke alarm is preorder.
plumber77
Posts 76
plumber77 replied on Sun, Oct 13 2013 10:58 PM
http://www.salus-tech.com/products/thermostat/it500/
Salus are available in the UK
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Oct 14 2013 1:29 AM
This is probably no help but here in the US I have a Radio Thermostat Company Of America CT 100. It is a Z Wave device so you need either a Z Wave Bridge or like I have a wireless based alarm system that supports Z Wave devices. I will say such things are quite convenient, being able to set it remotely on the road away from home so the house is at the proper temp when you get there is great. Also, I tend to have my cell phone by the bed at night so it's easy to tweak the temp at night if need be.
The Nestis by far the most attractive one, and from what I hear works very well. I considered one as its compatible with my alarm system, but it's prime selling point, the automatic setup based on when it senses you're at home or gone doesn't help me, being retired and home most of the time. Someone is usually here. But it is by far the nicest looking.
Jeff
Livius
Posts 29
Livius replied on Wed, Oct 16 2013 6:45 PM
Nefit a Bosch Heating company us bringing out an Wifi Thermostat as well.  See: http://www.nefit.nl/easy (Site is dutch only)
The NEST is made for the US and only supports US based heating systems. It required to be set to an US zip code and time zone. I read somewhere NEST is planing on going to the UK in the future
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
I have been using Nests for a while now. Love them, and yes -they look great!
  • One B&o bottle opener
  • One fancy gun
Chris Harrison
Peak District
Posts 381
Well, Santa Claus came and brought me a Salus IT500 thermostat which connects to our combi boiler and control via iphone/ iPad / PC/Mac etc and its brilliant.
Works really well....very happy.
Simonbeo
Posts 1,451
Simonbeo replied on Sun, Dec 29 2013 3:04 PM
Just saw them on the shelf in our local apple store , the Nest, that is.
and we have a Honeywell CM 727 thermostat , installed with our new boiler a year ago . Never used the wifi feature but know it has a detachable display / thermometer , if that's what you're looking for?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Dec 29 2013 6:25 PM
look at this smart thermostat.
http://www.tado.com
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Page 1 of 1 (11 items) | RSS
