Ipod to ML/MCL convertor?
This post has 3 Replies | 0 Followers
beaker
Posts 761
beaker Posted: Tue, Oct 15 2013 3:12 PM
I have an ML/MCL convertor and a Beolink convertor sitting around and wondered is it at all possible using these bits to connect up an ipod and then on to a pair of passive speakers. Im not to clued up on these so it might be a silly question but i figured that theres an amp there so how can I use it.
BeoMegaMan
Posts 601
Technically you could use it to connect an ipod to and feed into a passive kit to then playback to the speakers. You'll need an aux in cable and then the passive kit with eye.
Ah, you know... A little B&O here, a little there
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Oct 15 2013 8:01 PM
take away the white stickers on your Beolink Converter NL/ML.
you will get
Line in, PL, IR eye connection.
you can connect the iPod to the two RCA line in connectors. you have to set up the software of the BLC NL/ML
BeoMegaMan
Posts 601
It's a ML/MCL and a BeoLink converter that he has not a NL converter.
Page 1 of 1 (4 items) | RSS
