Beogram 8000
This post has 40 Replies | 2 Followers
Orava
Finland
Posts 991
Orava Posted: Thu, Oct 17 2013 6:24 PM
Well, hope not beging of WW3, but BG8000 thread
Startpoint
 soon...:
Hey, look! No tools! Yet
Orava
Finland
Posts 991
Orava replied on Thu, Oct 17 2013 6:27 PM
Nasty suprise if plugged in. Loose metalplate, whats it for...??
No supporting rod like in 59XX series
But luckily I have Europa
How to disasseble tis...
and tat....
Orava
Finland
Posts 991
Orava replied on Thu, Oct 17 2013 6:29 PM
Ah, transformer goes up, and board is off the hooks.
Orava
Finland
Posts 991
Orava replied on Thu, Oct 17 2013 6:30 PM
And by one screw...
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:01 AM
This was a bit difficult
But it gave up
Smells like recapping
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:04 AM
All stripped
Not burnt, but dusty
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:07 AM
Intresting switch in panel
Remains me about BM1900 series volume control, same designer?
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:11 AM
Compared to 59XX, this is almost like heavy industry
And downunder
Indicator ready to rebulbed
I wonder why R1 is here called "photo element" and elsewhere "photoresistor"? What is the difference between?
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:13 AM
Recapped
Orava
Finland
Posts 991
Orava replied on Fri, Oct 18 2013 7:16 AM
Ouch, indicator signal dissapears to somewhere here
Changed transistor, and signal comes through and platter ribs are seen
Still it wont regonice edge of disk, what is wrong? Confused
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Oct 18 2013 8:55 PM
Could you be more specific? Does it go all the way to the end of side? What does it do then?
By the way, have you yet checked this setting?
Jacques
Orava
Finland
Posts 991
Orava replied on Mon, Oct 21 2013 5:03 PM
Today back by the bench again.
Hi Jaques. Yes I did adjust them.
If I just ress play, it goes right to the end, and I bet it likes to go over if could. However, if there is a singe on platter and go back to rib area, press play, it founds edge allright.
Thinking, thinking....
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 21 2013 5:46 PM
Okay but does it play the EP disc?
Is the SO switch present and correctly mounted?
Does the sensor counter circuit work? The IR diode is fragile and can go belly-up. If the processor doesn't see a certain number of pulses (the Beogram 8000 counts everything!) from the arm carriage screw tacho (motor side) it won't stop. Check this circuit.
The platter ribs are there for no disc or EP/45RPM only so that works.
What I did:
Jacques
Orava
Finland
Posts 991
Orava replied on Mon, Oct 21 2013 7:09 PM
Oh yes, it does play small ones.(singles)
I check that counter sensor works, but havent check it any deeper, will check tomorrow.
SO switch? Switch Off? It works.
Mechanically this looks more simple if compared to 59xx, but no wonder if it counts it's way.
Orava
Finland
Posts 991
Orava replied on Tue, Oct 22 2013 7:20 AM
Just tought, is this working by contrast difference and thus by edge, not by level, of signal from indicator arm? If so, maybe it just do not get clear enough signal without topplate?
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Oct 22 2013 8:17 AM
It works fine when it is in service position. Try with a 25 cm record I'm sure it will work too. Have you checked with a camera that the it diode works?
Jacques
Orava
Finland
Posts 991
Orava replied on Tue, Oct 22 2013 10:17 AM
Npe, just output from detector diodes
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Oct 22 2013 10:35 AM
So you see the pulses? Does it count?
Jacques
Orava
Finland
Posts 991
Orava replied on Tue, Oct 22 2013 5:58 PM
Yes, I see, no problem.
How it should behave? When I press Play and there is not disk? Mine seems to be happy to go all the way to end and beyond. Also it do not return after disk is at the end.
When it plays, it works as it should.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Oct 22 2013 7:33 PM
When there is no record, it goes straight to the end stop and comes back to an end.
Jacques
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Wed, Oct 23 2013 2:55 AM
Does the bulb at the end of the detector arms lights up when play is pressed? (not the red light, the one under the arm..). I had somewhat a similar intermittent behaviour in the past: when that bulb is off and no record is present, it acts the same way as in your description: the carriage goes forward forever... in my case, the failure was caused by a cracked solder joint somewhere (if I remember correctly) on the P3 connector...
The same thing happens if the IR light of the OPE1 (near the carriage motor) is dead... but it does not seem to be your case...
Orava
Finland
Posts 991
Orava replied on Wed, Oct 23 2013 4:47 PM
Hi
Yes, it has new bulb.
When I drive arm at edge of platter there is a clear voltage change between platter and non platter, but if there is a record on platter, no noticeable change. Do this count where edge should be rather than detecting it? Is there anywhere flow/timing chart for this?
I'm afraid, next thing is μP...
And schemas I have are somewhat different than actual player.
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Wed, Oct 23 2013 9:27 PM
Another thought...
Could it be that one of the two phototransistor in the OPE1 has failed? I don't clearly understand how they function but I think that they allow the machine to count forward and backward. I think it's well documented in the technical manual for the beomaster 8000: the volume encoding wheel and tuning wheel operates in the same manner (I think..)
Anyways... If one has failed that would explain:
-That the machine receives only half the pulses it receives when operating properly, so it counts the position of a 12', 2.5' later (to the position of a 7'), thus the effective drop of the tonearm for a single.
-That the arm does not return at the end: it has not finished counting when it reaches the end so it does not come back....
One thing for sure: if the IR led in OPE1 fails, then the carriage would go forward forever, record or not... I think that the detector arm has to see the ribs of the platters (or not) AND it has to count...
Guillaume
Orava
Finland
Posts 991
Orava replied on Thu, Oct 24 2013 6:56 AM
Yes , it has two phototr's to know direction. They both do produce nice wawe, so I think they are ok. And if, while single is on platter, play is pressed while arm is on top of platter outside of record, it finds edge, and knows how long beyond that it has to go to get needle also on top of record > counting is ok, in that case anyway.
So is there a problem to see edge of LP? As there is not noticeable change when passing over it, I think there should be as above on singles case....
Continuing testing...
Orava
Finland
Posts 991
Orava replied on Sat, Oct 26 2013 4:18 PM
mmm, first lesson forgotten, Take enough time to check and double check.
You people were right on right tracks, second counter do work ok, but didn't survive through op.amp. So change LM324 and, voila, counting reaches the μP.
So, it counts it's place with double detector at end of saft, and detector arm is only to see if there is record or not.
Now, should it move fast to edge of record and slow down before stop?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 26 2013 4:27 PM
Yes that's how mine behaves.
Good work!
Jacques
Orava
Finland
Posts 991
Orava replied on Sun, Oct 27 2013 9:29 AM
Thanks, it seems that I have to clean motor itself also. It is a bit difficult to it to move slowly.
On the other hand...
it looks so tight packet... I'm not going to mess with it.
Cleaning rails with proper grease and good new belt will do.
Orava
Finland
Posts 991
Orava replied on Wed, Oct 30 2013 2:50 PM
And here she is, playing happily Lee Clayton.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Oct 30 2013 8:49 PM
Nice! Now what cartridge do you use?
Jacques
Orava
Finland
Posts 991
Orava replied on Thu, Oct 31 2013 6:43 AM
At the moment there is 20S, but I have few 20EN's to try.
(oops, isn't that dirty record on pic....)
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 31 2013 7:34 AM
Then you will only get a glimpse of what the deck is capable of: you really need a 20CL or a Soundsmith cartridge!
This combination made me give up on lesser Thorenses (TD160 et al) and  Rega'd Technics SL1200MkII.
Jacques
Søren Mexico
Mexico City
Posts 6,411
Good job Orava, and you woke up my virus again, but I will resist, no more buys before all my waiting items are up and running.
Orava
Finland
Posts 991
Orava replied on Thu, Oct 31 2013 12:34 PM
But it is quite intresting player, belive me Wink
Or did you mean 20CL?
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Thu, Oct 31 2013 11:55 PM
Congrats on resurrecting this fabulous machine!...The MMC 20CL is known to be the best cartridge that B&O ever produced. I agree with Jacques that this turntable deserves it if you can afford it.. But it's pretty expensive on the used market... In comparison, the 20S is completely at the opposite on the quality level. But hey! it's best than having no pickup at all!... (I have a MMC 10E on my beogram 4002 and I think it's decent anyway...( a mmc 20 EN would satisfy me though..)
When I got my beogram 8000, I thought it was a pretty boring machine compared to the 4000 series, But with time it has became one of my favourite B&O piece: It screams the 80's and it operates more smoothly than the 4002 (or at least my 4002 (less kling! klang!)). The tengential drive is fabulous: when stopped, the platter even brakes. And the repeat function, although somewhat useless, should have been a pretty big Wow! factor back at the beginning of the 80's (It impresses all my friends, at least..)
I wonder how it would have looked like if it would have been designed out of the Beolab 8000 system. Would the angled lid have been kept? Or would they still have kept the arms out of view under an aluminium panel?
Guillaume
Søren Mexico
Mexico City
Posts 6,411
Orava:
I would love to have the player (and the 20CL), But then I will have to have the BM too, and then speakers that fit, maybe next year. Or the year after.
Orava
Finland
Posts 991
Orava replied on Fri, Nov 1 2013 6:49 AM
hamacbleu:
Guillaume
Thanks. Exactly same impressions, I have two 400x waiting to be refurbed, and in lookwise they are a bit more intresting. Have to see what happens.
8000 Is intresting techwise, and after all suprisingly simple, compared to 59xx series, mainly because electronics drives and stears, not sprocets.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 1 2013 8:38 AM
Søren Mexico:
Exactly. You'll also need the Beocord 9000, yet another must-have. This never ends.
I don't like the cog-and-wheel mechanisms of later - and final - Beograms either. I do have a 5005 and am not impressed at all. The bearing is just ridiculous, and it breathes cost-cutting!
And yes the 4000 series are noisy in operation!
Jacques
Orava
Finland
Posts 991
Orava replied on Fri, Nov 1 2013 9:08 AM
chartz:
Ear muffs on a list !
Orava
Finland
Posts 991
Orava replied on Wed, Nov 6 2013 5:13 PM
How do you clean stylus safely in this?
Søren Mexico
Mexico City
Posts 6,411
Orava:
Here
Page 1 of 2 (41 items) 1 2 Next > | RSS
