Beo 1
beopuig
Posts 23
beopuig Posted: Thu, Oct 24 2013 10:56 AM
Does anybody know if a Beo1 remote can be used for other B&O equipment apart from the Beocenter 1
the_o_master
Posts 856
I am not sure for other B&O equipment but with my BV8-26 it didn't work.
I presume it was designed/developed only for Beovision/Beocenter 1
Vintage Bang & Olufsen
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Oct 24 2013 3:28 PM
beopuig:
Yes. Beo1 can act as a (limited) Beo4 in video mode. So you can control every BV (and linked audio sources) with your Beo1.
You have to reprogram your Beo1 to Beo4 mode.
More info: http://archivedarchivedforum2.beoworld.org/forums/t/29071.aspx?PageIndex=1
Stefan
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Oct 24 2013 6:23 PM
stefan:
beopuig:
Stefan
My Beo 1 is just a collectors piece. It would not reprogram successfully, and I suspect that that is the experience of about 50% of those who try.
i have a suspicion that many that appear for sale on the likes of eBay have already failed the reprogramming and that is why they are being sold (often with  the suggestion  that the buyer can reprogram it).
Graham
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 24 2013 7:12 PM
I had to try re-programming several times on both my Beo1s, and eventually it just worked.  I seem to remember taking the batteries out a couple of times to 'clear' it before re-trying! It may be worth persevering!
beopuig
Posts 23
beopuig replied on Thu, Oct 24 2013 8:31 PM
Thanks! Very useful information.
Joan
Page 1 of 1 (6 items) | RSS
