I have just brought another beolit 600 (bloody beovirus), and I was wondering if I could attach an airport express and use it in the bathroom?
In the user manual it does say "If you prefer, your dealer can rewire this jack for use as a phonograph input for a crystal or ceramic cartridge of your chaise, rather than as a radio tuner output"
I was wondering if I had read this correctly so the T. Tape Recorder jack can be used as an input.
Has anyone done this?
Toby
I have not done it as you describe but it will work.
Peter
Thanks Peter, will have to have a look at service manual and work out how to do it.
