BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Sorry, my BV11 had the same udate without having any problems afterwards (so far
Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11, Beoplay A9 Mk4, Beoplay E6
Mine updated without any issues. Got the software update information page, hit the 'Done' button, then the TV came on after a 20 sec blank screen with just sound.
Is it possible that your update got interrupted or corrupted? Try downloading the software update again via the menu page.
Graham
No, this is not the reason. The PIN Code is off.
Strange thing is, that it works for some time, then it freezes and switches off. Sometimes this takes just a minute, sometimes more than 30 minutes...
Mine is on a motorised hinge. TV now seems to move to the video position on switch on as before, but takes longer to 'open the curtains' to show the picture than it did previously.
hello,
my tv (11-55) has the same problems.
nearly everything is workong slower. if i switch between programs he freezes nearly every 2-3rd time. using dtv is nearly impossible, he looses the curser and stops working.
after about 1 minute he switches of, and everything starts again....
the only thing that works as expected is spotify. :(
horst
hgitzoller:I found out the SW did not finish. Version was set to 0.0.0.0. New manual update lead to a more stable version. But now as I need to do a complete new setup it still freezes quite often and then switches off after 10s of freezing. Then I can switch on again and the game starts again... -------------------------------------------------------------------------------------------------- BV 11-46 / BV 8-32 / BV 6-26 / Apple TV 1+3 / Beomedia 1 / BL3 / 2* BL11 / BL 6000 / BL 2000 / Beoport / 4* Beo4 / Masterlink over Ethernet
go back to the factory default. you have to reinstall your settings though
(in Setup: red button en immediately GO/press the stick)
