Set up is BV 7 and BS9000 in same room, surround sound. Have not used 9000 for some time but when I used it recently, sound only came out of Left speakers. No problem with tv or Apple TV. Have checked sound settings and it i speakers 4 for audio. Any thoughts. I'm thinking it's something simple I have forgotten to do
Check your MasterLink cables/if the plugs are pushed proper in.
N.B. 4 posts - how many sound problems/setups do you have
Will do. Thanks
and yes, I thought I'd deleted 3 of them!
Tried that. All firmly in place
any other thoughts?
double post
If you have junction boxes in your ML loop, I would look at all of them for slipped or broken wires.
