My daughter wants some thing portable to play music through her i pad. I was wondering if any one has experience with the A3. Would you recomend it ?
Plenty of previous feedback if you try the search function!
Highly recommended for all non-lightning connector iPads. Very good sound output. Can be easy to knock over, so always needs to be placed on very level surfaces in a location where it is unlikely to be accidentally knocked.
Graham
