Beovision 7 -40 Type 9456 with Beo4 with Nob
This post has 3 Replies | 0 Followers
georgey007
Posts 74
georgey007 Posted: Sat, Nov 2 2013 8:26 AM
Hi
I'm thinking of buying a Beovison 7-40 Type 9456 and my question is if the TV takes full advantage of the new Beo4 with nob? Can I change the used Beo4 in the Menu like on the the Beovision 10 ?
To know would help me a lote becouse the puc for my stb is easyer if its suported !
regards
Millemissen
Flensborg, Denmark
Posts 14,680
You will see that in the menu of the BV7-40.
If you can switch between both, it will be fine.
Don't know it by 'Type xxxx', but it also depends on the SW-version.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Nov 2 2013 11:26 AM
Looks like you want to buy an MK IV TV only model. This BV should natively support Beo4 navigation stck (1710).
If you buy from an authorised Beo dealer, just make sure that your BV will be updated to latest sw.
And yes you can select Beo4 navi in the BV7 menu.
Stefan
georgey007
Posts 74
Yes I will buy from my lokal dealer so i will have latest firmware :)
thanks
Page 1 of 1 (4 items) | RSS
