MC/MCL converter 1651
Geurink
Posts 18
Geurink Posted: Mon, Nov 4 2013 12:44 PM
Hello,
I have a MC/MCL converter 1651 whit have the problem that is shutting off after a few seconds. Even the red indicator is going out. It also happens when nothing is connected.
Have anyone a suggestion what could give the problem.
Regards  Frans
BeoMegaMan
Posts 601
Probably an amplifier failure or lack of proper source. What is it connected to and how?
Ah, you know... A little B&O here, a little there
Geurink
Posts 18
Geurink replied on Mon, Nov 4 2013 8:05 PM
Thanks for the replay,
Normally I use the Master link. But it stops also when I do connect anything.
regards  Frans
BeoMegaMan
Posts 601
If you have a fully mounted powerlink cable connect it to your master and connect a passive speaker to the MCL. Once you power on the source you should be able to get audio. If it works it could simply be a configuration problem. If you still get nothing, then it may be time for a repair.
Page 1 of 1 (4 items) | RSS
