Beovision 7 ML and Apple TV
Laerdal
Posts 3
Laerdal Posted: Mon, Nov 4 2013 9:43 PM
I have a Beovison 7 as video master. I have Sky connected. There is an MX4002 and a Beovision 6 both of which receive Sky through the ML cabling. I have an Apple TV connected to the second HDMI socket on the BV7 and it works really well. It is set as PC. However I cannot get it to come though to any of the other TVs.
It either isn't possible, or I'm missing something. Any suggestions?
elephant
AU
Posts 8,219
elephant replied on Mon, Nov 4 2013 10:12 PM
Laerdal:
You have a nice setup.
You should be able to get the ATV's audio through to the other rooms (if the BV7 is up to date) - just try pressing (say) [AV} and then [DVD] (if that is what the ATV source is defined as).
However I do not believe you will get the digital picture sent through - just the digital audio was convert to analogue audio and sent through.
And when you said that the BV7 sends it video through ML I believe you were wrong; you must wither be using the B&O RF Modulator that sends the BV7s video through a coax that runs parallel with the ML, or you must have an aerial splitter ?
Options that spring to mind that you might consider or want to debate are:
(a) using an original ATV on the BV7 - the one with a hard drive, it would output an analogue video - but I would not recommend investing in technology that is so "old" to be you main driver of content
(b) buying a second ATV if the BV6 has a DVI port - and an HDMI to DVI cable and a parallel audio cable from the ATV to the BV6 - you should find a couple of threads about such a setup.  I have separate ATVs attached to my BVs and that seems an ideal solution (for me).
(c) however for the MX only an old/original ATV would work - as you will need analogue connections
(d) look at something other than an Apple TV (depends where your content is coming from) such as a Western Digital device - again though you will have to find one that outputs an analogue video signal for the MX
Hopefully others will weigh in and correct any mistakes / assumptions I have made !
BeoNut since '75
Laerdal
Posts 3
Laerdal replied on Mon, Nov 4 2013 11:20 PM
Thanks. I'll digest that and see if I can work it through. You are correct about the Sky set up - the video is distributed by co-ax and that will be the problem with the Apple TV.
Laerdal
Posts 3
Page 1 of 1 (4 items) | RSS
