No, but you can put it in a power off mode in 1,2,3,4 hour increments. Meaning it will power off if no buttons are touched in the listed time frame.
Ah, you know... A little B&O here, a little there
Actually it DOES have a sleep timer. Press LIST on your Beo4 until you see SLEEP in the display. If it is not available you can add it. Thats another story however.When you have SLEEP on your display, just hit the GO-button (joystick click) and you will see a time on the screen, press again to increase the time.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
