What is the easiest or correct way to replace the drive belt?
thank you.
Take of the record plate and you will see
What Søren shows you is correct for Beogram 1202 and 1203.
The Beogram 1200 platter is held by three screws under the center tap.Pull off the center tap and you will see the three screws.
Dillen:What Søren shows you is correct for Beogram 1202 and 1203.
Again, thank you Martin
