HI Chris,
Did you select speaker 5 ? Even with only 2.1 surround, the sound is very improved.From a bluray you are then in dts instead of pcm.
You could add a sub. As I wasn't satisfied by the beolab 2, I bought a kef HTB2 and it works perfectly with my bv 7.40. Bought from ebay UK for only 250 euros delivered !
Soon, I will use the bl14 sub instead of the kef or maybe I will use both.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
4000s are excellent speakers - wall mount them and they have plenty of bass. I use a pair as fronts with an Avant and another pair as rears with my BV5 where they wasted really. Take a trip around Struer and you will find them all over the place.
Peter
The problem I had with a BV10 was not bass, which a BL2 sorted, but presence - the upper bass. Tweaked it all ways and always sounded thin. The BV5 is much much better. I thought the BV11 was supposed to be better. I guess you should try a BV11 as that is supposed to add exactly the sound I found missing.
I thought you'd swapped the BV11 for a BV7.
Ban boring signatures!
Or tell it that you have attached something else!!
