Connecting Beovox S75 to Beosystem 5500
This post has 6 Replies | 0 Followers
garethsouth
Posts 4
garethsouth Posted: Mon, Nov 11 2013 10:57 PM
I've recently acquired the full Beosystem 5500 and a pair of Beovox s75 speakers. I'm at a bit of a loss as the cable which go into the system are bare wire and the system looks like it has some sort of pin attachment needed for connection. Can anyone give me some advice on how I hook them up. I know I;m a complete rookie but I think I have some decent kit and want to be able to use it now!
Many Thanks,
Gaz :)
Steffen
Denmark
Posts 1,408
garethsouth
Posts 4
Thanks so much for getting back to me! That's brilliant will I need to solder the wire onto the inside or is there some kind of clip?
Cheers,
Gaz :)
Steffen
Denmark
Posts 1,408
Steffen replied on Tue, Nov 12 2013 10:49 PM
As mentioned on the homepage, if you follow the link: These ones have screw terminals Wink
Here's a picture of one of my own DIN plugs:
You can also get other types where you can solder the wires.
garethsouth
Posts 4
absolutely superb sir! thank you so much!
Cheers,
Gaz :)
garethsouth
Posts 4
Cheers,
Gaz :)
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Nov 14 2013 12:23 AM
You're welcome. Glad that I could help you. Smile
Page 1 of 1 (7 items) | RSS
