Beocord 2400 Cassette Deck - advice needed
This post has 0 Replies | 2 Followers
christianl
Posts 1
christianl Posted: Fri, Nov 15 2013 9:31 AM
Hi
I have recently acquired a Beocord 2400 and I need advice about a couple of things. Sometimes, OK quite often, the right channel has a loud buzz when pressing 'Play' and the VU goes to max. As soon as I press 'Record' the VU goes down again. I have tried to cure it with some squirts of contact cleaner and there has been a slight improvement, but I guess there must be a switch I have missed. Any hints?
Also I think the AV output from a 90s Rotel amp seems higher than the Beocord is designed for - if I record I have to set the levels really low. Is there any workaround for that kind of issue?
I am grateful for any advice.
Page 1 of 1 (1 items) | RSS
