Hi
I have moved into a new house which the previous owner has set-up Beo speakers wired into several rooms.
However there is no Beo amplifier to power the system, but the speakers in the lounge are Beolab 2500.
I would like to make use of the existing set-up but need advice as the connectors seem to be quite old.
There are 4 x 8 pin plugs together with a 16 pin connector to plug into a device plus a another 16 pin connector to plug into a wall socket.
Can anyone please tell me what options I have re: buying the correct used Beo amp or possibly getting some connector adapters to fit newer kit?
Any advice to get the system working one way or another would be much appreciated.
Many thanks
Hodgey
Welcome to Beoworld, there are several options you can go for. First thing is to test all cables for continuity but it does sound like they should be intact.
Next you need select what you want, cd tape mp3
Many thanks for the welcome!
Ideally I would like to use my iPod, however cd would be the next best option.
Maybe photos to show?
You could start with a Beosound Ouverture (or similar), good match for the Beolab 2500 and has got Masterlink Connection.
Ralf
So, only Masterlink and 4 Powerlink plugs/cables.
Looks like there has been a TV in this area....(with Dolby surround) OR 4 Speakers attached to one Music System.
Do you happen to know where the Powerlink (8 pin cable) cables run to?Maybe there are wall plugs where activer Speakers have been.Would work with an ouverture for Audio only as well (or any other System that can drive active Speakers).
Masterlink is for room to room Distribution of the Sound.
The power link cables run to two Beolab 2500 speakers in the lounge.
I assume the Masterlink drives the two Beolab 4000 speakers in the kitchen and two speakers built into the bedroom ceiling.
Am just looking for the simplest solution that would provide room to room sound.
Regards
Hodgey:The power link cables run to two Beolab 2500 speakers in the lounge. I assume the Masterlink drives the two Beolab 4000 speakers in the kitchen and two speakers built into the bedroom ceiling. Am just looking for the simplest solution that would provide room to room sound. Regards Hodgey
BeoNut since '75
Yes there is an IR eye silver disc in each of the bedroom and kitchen, but unfortunately we did not receive a remote with the house.
is the Ouverture Beosound system still an option here and will it accept some kind of iPod connection?
Hi Hodgey, where are you located? Have you spoken with your local B&O dealer?
x:________________________
Hodgey:Yes there is an IR eye silver disc in each of the bedroom and kitchen, but unfortunately we did not receive a remote with the house.is the Ouverture Beosound system still an option here and will it accept some kind of iPod connection?Many thanks
One thing re the playmaker, you can get an Ouverture with a Beo4 remote for less than the cost of a Playmaker. Add an Airport or a dock and you get CD, Radio and ipod for less. And it will be compatible and have Masterlink!
I'm sure Ed and I can help you with a solution if you're local
Hi All,
Re: location - I am based just outside Manchester in Cheshire in the UK - if you know any contacts in my area that would be really useful.
It's going to be tricky to get into the loft to get information on the recessed bedroom speakers.
Hi Hodgey,
All depends on your budget of course but you are nearly there. I'd go for a BeoSound 3000 or even a 3200 as they are now pretty cheap on ebay.
I am in Halifax but don't really get over to Manchester much. Happy to help via telephone if I can!!!
Jonnie
