MLGW Telegram
This post has 8 Replies | 2 Followers
Hermann_
Posts 52
Hermann_ Posted: Sun, Nov 17 2013 12:03 PM
Hi
Has somebody an example for:
A telegram sent by a third party product which starts an event in MLGW?
Thank's a lot, Hermann
claudiu
copenhagen
Posts 193
claudiu replied on Sun, Nov 17 2013 12:29 PM
I think we need to use "Scheduler"
I tried many times but fail to give a time in  Macro.
mjmedlo
Posts 922
mjmedlo replied on Mon, Nov 18 2013 1:18 AM
What are you trying to do ?
I have lutron trigger B&O regularly.
What do you mean by the 'telegram'?
Hermann_
Posts 52
Hermann_ replied on Mon, Nov 18 2013 2:36 PM
I have my Conson house control system connected to the MLGW via the RS 232 interface.
From the B&O app I can both, control multimedia devices and the Conson lighting also. So far so good.
Now I would not use the B&O app, but CommandFusion (is much confidential). This means, I want to send a signal from the house control system via the RS 232 interface for MLGW. And this is exactly my question, how should look this so called telegram?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Nov 18 2013 4:45 PM
I have no Conson house control, but my MLGW controls a Lintronic relay board via RS232.
You have to set up your MLGW for RS232 use. Set baudrate, stop bits... of your Conson in the MLGW, and find out which RS232 commands the system uses. You can jaust put it in by numbers.
Maybe this helps (?):
http://www.commandfusion.com/wiki2/hardware/cflink/on-board-rs232-port-protocol
Stefan
olvisab
Posts 1,391
olvisab replied on Mon, Nov 18 2013 10:01 PM
Hi
sorry to disturb your interessant discussion, I just bought a secondhand MLGW and I don t know how to find the configuration tool ?
THanks in advance for your help
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
stefan
Posts 2,920
stefan replied on Tue, Nov 19 2013 6:36 AM
You dont need a ct. It uses a webinterface.
http://mlgw.bang-olufsen.dk/source/documents/
Stefan
Hermann_
Posts 52
Hermann_ replied on Tue, Nov 19 2013 8:23 PM
Hi Stefan
Thank's for your help. Unfortunately the protocol from CommandFusion doesn't help. They use an other telegram syntax. My search for a solution is going on.
Hermann
olvisab
Posts 1,391
olvisab replied on Tue, Nov 19 2013 8:32 PM
Hi Stefan
Thanks for this precious information !!
Best regards
OLivier
Page 1 of 1 (9 items) | RSS
