Hi, my avant has been acting up after a lightening strike on our power lines.
the picture now bends down both sides when any straight lines are visible. Otherwise picture is fine.it will fill the whole screen giving a perfect oblong shape with straight edges. But if there are straight edges in the picture for example a building the building edges will curve on the vertical line. Horizontal lines are ok.
is this anything that can be adjusted in say the service menu screens?
thanks for any help.
