XBOX One?
This post has 3 Replies | 0 Followers
IngvarW
Sweden
Posts 38
IngvarW Posted: Mon, Nov 18 2013 8:10 PM
Hi, will I be able to control the XBOX One via Beo6? What updates have to be done to my BV10-46?
Brgds Ingvar
Current; Beosound 2, BV Horizon 48,  2*BL3, BL11, Beolit 12, Beolit 15, Beoplay P6, Beoplay A9, Beoplay H9i
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
BeoMegaMan
Posts 601
There is IR on the Xbox One, so yes it will control it. The question is will it run off the old 360 codes or will another PUC code profile have to be created....... we'll know soon as the product launch is right around the corner. If it requires a new PUC code then your dealer will have to plug into the 10-46 to give them to it.
Ah, you know... A little B&O here, a little there
beoaus
Posts 177
beoaus replied on Wed, May 7 2014 2:32 AM
Any chance a new PUC code was created?
Thanks, beoaus
PapaJustify
Posts 110
No, we don't have a PUC code for the Xbox One Media Remote yet. But it would definitely possible to make and eventually put it on a BEO6.
Page 1 of 1 (4 items) | RSS
