Hi
when i plug a beolab 14 to the main do i have a led in order to see if it works ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
In the evening turn the lights off and definetely you will see a led (or not). Mine is still in the box but will try when I'm back from my trip. Just heard from my dearest thst Steve's cables have arrived....
Brengen & Ophalen
It will turn green as soon as you feed it a signal and turn red as soon the signal stops.
There is no way to tell if its working just by plugging it in to the AC socket.
http://bogous.custhelp.com/app/answers/detail/a_id/8858/session/L3RpbWUvMTM4NDg0NzEwNC9zaWQvNUk2MW9KRmw%3D
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
Hi MikaelHansen
You mean that when you don't send a signal to it ( plugged or unplugged from a source) there is absolutely no red light at all.
When it receives a signal, the led become green for 10 secondes.When the signal stops then the red light stays 10 seconds only.
Is it like this ? For every b&o activ sepakers we had always a red light which indicates that the speaker is in stand by mode.
THanks in advance for your explanations
Yes, it's precisely like that.
There is no constant red light when its off. Only for the first 10 sec after the signal is stopped. No light at all when you just plug it in. It needs a signal to show life signs :)
Well, I have left one for repair just for this little special behaviour, I thought he was dead.
I think that I have to call them before they open it. The repair center is usually a trustable center, but with these new little chinese toys everything seems different.
Again thanks for your help
