Now that my Redline speakers are sounding fantastic, I am looking for a reasonable solution to hang them from the wall. Has anyone had any luck with any non B&O brackets to do the job? or has anyone had something custom made that they're happy with?
There is a pivotal wall mount bracket for sale online but it's pretty expensive... so before I fork out even more cash I'm curious to see what other people have come up with.
Any references or photos would be greatly appreciated!
Cheers!
If you want a very cheap solution, you can do like I did back in the 90's when I had a pair of RL 60.2's -and didn't want to buy the original wall brackets.
Simply buy some wall hooks like the ones in the picture - 2 for each speaker. Then you can hang them in the standard 'flip-out' brackets on the back of the speakers, intended for floor standing. It worked fine for me. I had them hanging on the wall for years.
Wall hooks:
If you want static ones search eBay for part number 13080604. QDA have some for £30 with free p&p.
I searched ages for mine and ended up buying on US eBay for about £20.
For that amount you can have mine complete (excl. shipping costs)
Brengen & Ophalen
