What Stylus/Cartridges will fit a B&O Beogram 5500 Turntable
kapet
Posts 1
kapet Posted: Sun, Nov 24 2013 4:58 PM
What Stylus/Cartridges will fit a B&O Beogram 5500 Turntable and what would be the best one for it ? Do the B&O cartridges just plug right in ? Also where is the best place buy one ? Any help with this would be greatly appreciated . Thanks .
SHEFFIELD
Posts 262
SHEFFIELD replied on Sun, Nov 24 2013 5:33 PM
The MMC1, 2, 3, 4 or 5.  Most replace with a SMMC4 from Soundsith in the USA
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Nov 24 2013 7:33 PM
or www.schallplattennadeln.de
Ralf
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Sun, Nov 24 2013 9:19 PM
Note that MMC1 is the best and MMC5 is the worst...
x:________________________
Søren Hammer
Denmark
Posts 953
Jonathan:
"worst" you say... The MMC5 is still perfectly capable and quite respectable with an effective tip mass of 0.5 milligrams and a similar low compliance, just like the upper tier range. Would put it that the MMC1 is a selected version of the MMC2, being the most capable models with nude fine line diamond tips on sapphire cantilevers while the MMC3 was a nude elliptical on thin aluminium cantilever; the MMC4 and MMC5 was ordinary elleptical - still an upgrade from the MMC20S (spec wise) which is one of the best sounding B&O cartridges in my opinion.
- Søren
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Jonathan
Posts 1,811
Jonathan replied on Mon, Nov 25 2013 7:45 AM
Correct! The MMC1 is the best, and the MMC5 is the worst. The MMC1, 2, 3 and 4 are better than the MMC5 so this makes the MMC5 the worst
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Søren Hammer:
Jonathan:
"; the MMC4 and MMC5 was ordinary elleptical - still an upgrade from the MMC20S (spec wise) which is one of the best sounding B&O cartridges in my opinion.
- Søren
The MMC5 sound inferior to MMC4, even to my aged ears. This is apparently achieved by changing the cantilever shape and a lower tip mass.
The most cost effective "new" cartridge is to buy a repaired MMC4 from Axel in Germany.
Regards Graham
Page 1 of 1 (7 items) | RSS
