Beovox MC120-2 crossover mod?
This post has 10 Replies | 1 Follower
chartz
Burgundy, France
Posts 4,171
chartz Posted: Tue, Nov 26 2013 3:46 PM
Hi, I'd like to boost treble a little (2 dB). Now what resistor should I alter? R4 or R5? Both?
Thank you !
Damn, I've lost my stars! I'll do that later Stick out tongue
Jacques
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Nov 26 2013 4:06 PM
3dB is the smallest difference in sound pressure an human ear can recognize.
//Bo.
A long list...
Christian Christensen
Stockholm
Posts 512
Yes, some physical experiements, say that human ear cant hear difference in less then 3dB, but i reality, my experience is the oposit.
Less then one dB differnce is difficult for my ear, but I tune equalizers dB by dB thousands of times a day in my work and to me a 2dB change is dramatic.  I guess this is different for people.
I am not super expert in crossover but my suggession would be for you to soldier a 7 or 8 Ohm resistor parallel with R4, to achieve a 2dB boost.
Smart thing with soldier parallell is that by two cuts of the pliers you are back to orginal if you are not happy with your mod.
My re-capped M75 are my precious diamonds.
Søren Mexico
Mexico City
Posts 6,411
chartz:
Try to get at least 5 stars, you deserve it.Laughing
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Nov 26 2013 5:30 PM
Christian Christensen:
I suspect it will also alter the crossover frequency of the tweeter network (more so than a larger R5 would). Modifying the original design will mess up the crossover somewhat anyway, so I don't suppose that would be any issue in practice, and the way you suggest is easier.
--mika
Stockholm
Posts 512
Mika, yes I suspect a slight differnce aswell, being not the bigest expert on crossovers, but in state of  capacitors passing through, you can see the  as a resistor network and thats how I see it.
Then how much this small change of change would affect the filter frequence and steep is for people with more knowledge then I to respond.
Anyone here for an qualified answer ?
Stockholm
Posts 512
chartz, try
Its not gonna kill your speakers, even with a slitght change in crossover point.
I did similar change to my M75, and the reslut was wonderful
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Nov 27 2013 6:12 AM
Thanks for the answers!
I would like to achieve that treble boost and not change the crossover low cut frequency.
And the MC120 being a pain to open...
Jacques
Stockholm
Posts 512
I have now talked with a friend that has designed crossover for years.
He has read the thread.
As R4 is in direct serie with a capacitor, yes  changing R4 will also change the filter frequence, but its a matter of only a  few procent .
His answer is that you increase the value of R5 with 50-100% which will force enough more current through the tweeter,   to achieve what you need.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Nov 29 2013 6:22 AM
Thank you very much!
I will do the mod, measure output and tell you whether it is an improvement.
Jacques
Stockholm
Posts 512
Consider that the tolerence of the capacitors in the filter by orginal is 10 to 20 %. imagine how  how filter frequence could change from intended point   ?, unless they were manually matcing capacitors a the factory, which we dont know.
So a few procent impact is really nothing.
Page 1 of 1 (11 items) | RSS
