Reference BE2000K4 Type 4104-3 Number 22083.
Having recently acquired this machine, I am having difficulty making stereophonic recordings on the radio input. With the Din plug inserted into the radio socket, and the left and right connections into a stereo radio tuner, the machine will only record on one channel at a time, i.e. with the left channel record button depressed only the left channel is recorded and with the right channel button depressed only the right channel is recorded, this is entirely normal. However, when both record buttons are depressed together to make a stereo recording, only the left channel lights up and records.
If the Din plug is inserted into either of the other two sockets, i.e. gramophone input, microphone input, both channels light up and record in stereo, it is only the radio socket that appears to display this anomaly. I have read the handbook that came with the machine and have followed the instructions but I am unable to make it work as described in the book. Could there be a problem with the machine, or am I doing something wrong with the controls? Any help would be greatly appreciated.
