Glass doors fell off
This post has 6 Replies | 0 Followers
Wouter
Netherlands
Posts 302
Wouter Posted: Fri, Dec 6 2013 9:27 AM
Hello,
Both glass doors of my mp 9000 fell off when my brother knocked it over. Everything works but I am unable to attach the glass doors to the four metal pieces. I tried double sided sticky tape, without success... Should I use glass glue or something else? Most of the black layer on the corners is damaged. Gluing directly on the glass wouldn't be the most elegant solution but I do not see how to "fabricate" a new black layer... Any ideas how to restore this?
Wouter
Orava
Finland
Posts 991
Orava replied on Fri, Dec 6 2013 10:53 AM
I did use clear epoxy glue, it is transparent and scatches on black  layer does not show  too disturbingly, but it goes case by case I think...
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 6 2013 1:34 PM
You're talking about the MCP AV 9000 right? Quite simple, remove the remaining epoxy glue from the glasspanel. Tape off the area and use black paint (spray). The brackets to be attached using epoxy glue 2 component. Make sure to locate them on the right spot or else the doors will not run.  smoothly. That's it. Or else pay me a visit and I will show you how to do that.
Brengen & Ophalen
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Dec 6 2013 9:55 PM
Mask area with tape.
Etch glass.
Paint.
Glue with super glue. (home made clip)
//Bo.
A long list...
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Dec 6 2013 9:59 PM
That's the way to do it. Good job Bo.
Brengen & Ophalen
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Dec 6 2013 9:59 PM
Thanks!Smile
//Bo.
A long list...
Wouter
Netherlands
Posts 302
Wouter replied on Mon, Dec 9 2013 5:07 PM
Thank you bo! Great pictures, they make it seem a piece of cake!
Leslie:
Leslie, I think that I will!  But first I have way too much non b&o related work to do... I'll send you a PM.
Wouter
Page 1 of 1 (7 items) | RSS
