Hello
No cover arts appears in the belink app when selecting cd or n.music.
(beomaster 5 in option 0, cd radio plays fine through the MLGW, beomaster5.local detected).
Why I cannot browse the file inside the beomaster 5 ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
HI
Thanks for your answer.
I have never had cover art and browsing.
Maybe be it is because my beosound 5 is in option 0. For this reason I didn't select it in the ML or NL product list in the MLGW beolink configuration page.
I have checked that there is no update for the iphone beolink app.
I have enabled MLGW STATUS on the beomaster 5.
Could you please, control your setting and tell me if there are different.
Hi olvisab,
the "browsing" function is only available with the iPad version.
Further more you have tell the MLGW that there is a BM5. There is a special menu for doing this at the bottom of the device page in MLGW setup. Underneath the NL products... Option 0 and so no entry within the ML device section does not bother.
Also make sure that BM5 and MLGW are running on the latest SW.
Best greetings.- BeoMotion
Hi Beomotion,
BeoMotion:the "browsing" function is only available with the iPad version.
Does it mean that I can't have any cover art neither ?
BeoMotion: There is a special menu for doing this at the bottom of the device page in MLGW setup. Underneath the NL products...
I have already done it. Thanks for the advice
BeoMotion:Also make sure that BM5 and MLGW are running on the latest SW.
Already checked
olvisab:Does it mean that I can't have any cover art neither ?
Unfortunately that is the truth at the moment. Only available on iPad.
