Hi
I have two BV 11.
BV 11 (Room 2) is under Settings --> B&O Connection configured as mapped to BV 11 (Room 1).
BV 11 (Room 1) is connected to ML/NL Converter.
ML/NL Converter has the role AV-Master. It is connected to BV 11 (Room 1). There are a few link labs connected to ML/NL Converter. Under source visible on ML i made for example, that BV 11 (Room 1) Radio will appear.
Unfortunately that doesn't work. Does anybody have a suggestion? Thank's, Hermann
have you plugged in a ML cable or are you using the converter as active kit with IR eye and PL connected to it?
- BeoMotion
If there is no source from NL working in ML System make sure the ML cable is pugged into converter properly. Sometimes it is not possible to plug in the ML connector correctly since it will not make "click" and can easily fall off.
I have it connected with the ML-Socket. And it is without IR eye.
I have controlled, it is connected proper.
Maybe somebody have an other suggestion?
Have you tried to restart the converter more than once?
I'm confused as to the question. What exactly are you trying to do? Is there an audio product on the system as well or just the BV11's? Since you have no eye on the NL converter how are you to control it when BL's are connected to it? MLGW?
Ah, you know... A little B&O here, a little there
Hermann_: Hi I have two BV 11. BV 11 (Room 2) is under Settings --> B&O Connection configured as mapped to BV 11 (Room 1). BV 11 (Room 1) is connected to ML/NL Converter. ML/NL Converter has the role AV-Master. It is connected to BV 11 (Room 1). There are a few link labs connected to ML/NL Converter. Under source visible on ML i made for example, that BV 11 (Room 1) Radio will appear. Unfortunately that doesn't work. Does anybody have a suggestion? Thank's, Hermann
Put the BLC NL/ML to V.Master. Choose one BV11 to connect primarely. Be sure you confirm every change with a "SAVE".
In the BV11 choose Setup, Product Integration, B&o connect. Be sure the Belink Converter NL/ML (or its alias) is selected (and stored)
