BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
The BV11 has an AV input that you can use but you need a special cable from B&O to use it.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
How about this one:
http://www.amazon.co.uk/Neet®-Component-Converter-Supports-Lifetime/dp/B002C7CCJ6/ref=sr_1_sc_1?ie=UTF8&qid=1386533655&sr=8-1-spell&keywords=ypbpr+hdmi+konverter+wii
together with this one:
http://www.amazon.co.uk/TeckNet-Component-Cable-Nintendo-Wii/dp/B000P0X2RS/ref=sr_1_2?s=computers&ie=UTF8&qid=1386533778&sr=1-2&keywords=Wii+cable
Should give you the best quality!
Or just this one:
http://www.amazon.co.uk/Wii-HDMI-Converter-WII2HDMI-CONVERTER/dp/B007PY3ZPG/ref=sr_1_1?s=computers&ie=UTF8&qid=1386533883&sr=1-1&keywords=Wii+cable
Greetings MM
Ups - these link are from the UK-Amazon shop.
Should be avaiable from Amazon.de (or similar) too.
