HI
I understand how to use source, favorites and virtual buttons, but I don't find an easy way to control some basicmenu functions like the "speaker" function.
I created a macro that works fine for a virtual button called "stereo" and one for "central speaker" and "5.1", but it will be far easier to have on the beolink app an UI for each kind of audio or video unit, with the essential functions.
My macro call the menu on my tv, then select speaker function, then choice (1.2. or 5), then exit, exit in order to close the menu and power off the screen. (audio listening through masterlink). too much complicated compared to a beo4.
Am I missing something in my setup ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
No you are correct in that fact that there is no simple solution just yet. I too wish there were simple discreet pre-setup buttons for stand and speaker groups in the MLGW experience. But you will have to keep building them until it comes from DK.
Ah, you know... A little B&O here, a little there
Thanks for your answer.
Well, the positiv side of the actual situation is that I just add what I need and I don't have to go through a too complicated UI with so much button I don't need.
Finally, It is maybe better like this.
