Hi
I tried a HDMI to DVI i cable between my bc 6 26 HD ready and :
- ps3 , no image at all
- tv box, half image is clear, the other half is composed of lines of colors.
It should work becaus emy bc 6 26 is HDREADY.
Do I need to use a component to HDMI cable ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
If you've set the PS3 to output at 1080p the screen cannot show it (it's 720p) and possibly the module can't handle it.. Try resetting the output of the PS3 to 720p and see if this helps..
Not sure about the TV Box!
I'm assuming you've set the video input to DVI-I in the connections setup?
Lee
Thanks lee.
This is logical. Maybe this is the same for my tv box.
I will let you know
Have a nice week end.
Best regards
oLivier
