beosystem 4
claudiu
copenhagen
Posts 193
claudiu Posted: Sun, Dec 15 2013 6:12 PM
I have an idea to change beosystem 3 of BeoVision 9 with beosystem 4.What do you think?
Is a good idea?
Barry Santini
New York
Posts 543
Faced with the same question, ive decided to wait and save for bno's 65-80" 4k future set
Chris Townsend
Qatar
Posts 3,531
Good idea.
mjmedlo
Posts 922
mjmedlo replied on Tue, Dec 17 2013 2:12 AM
It was suggested to me by a dealer to wait on the new panels as well
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Tue, Dec 17 2013 12:00 PM
What would the benefits be? I guess the video engine in the BS3 is good enough for the BV9...?
Too long to list....
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Dec 17 2013 3:56 PM
I wouldn't change my BS3.
You loose all the analoque connections and the superb scaler inside.
No ML standard. The BS4 is some kin of downgraded BS3. It has some benefits but not for me.
BeoMegaMan
Posts 601
Too many hoops to jump through. You'll lose your stand control, ability to trigger the screen on and off via RS232, you'll have to convert the HDMI out to DVI out, and you'll need to integrate the NL converter on the back for ML as well.......... doesn't make much sense. Just let the BV9 be a BV9, still an incredible screen!
Ah, you know... A little B&O here, a little there
Page 1 of 1 (7 items) | RSS
