The easiest is a Beogram 7000 - but these are very expensive. If I were doing this, I would get a Beogram 4002 and an external RIAA amplifier (which you need to boost the level up - the Beogrram 7000 has one built in). I think the BG4002 is far more stylish and has a very low amount of plastic in it so is likely to last longer!
Peter
I would suggest one of the newer decks, so you get the comfort of data-link compatibility, with built-in RIAA.
Suggested: Beogram, 7000, 6500, 4500, 3500
//Bo.A long list...
Unfortunately, the BS3000 does not have a Datalink enabled Aux socket. Hence my suggestion.
Peter:BS3000 does not have a Datalink enabled Aux socket
Hmmm...I did't know that. Why not?
The data link on the aux socket ceased when Masterlink sockets appeared. So from Ouverture onwards the BeoSound3000/3200 only have Aux in without data.
Opman
