A simple question (hopefully)... I've just bought a Beogram CD 5500 to go with my Beomaster 5000 and am trying to figure out what cable(s) I need to connect the two? Do I need a DIN to DIN so that sound and remote will work?
Cheers,
Tony
Yes - 7 pin DIN to 7 pin DIN.
Peter
I thought so, just wanted to be sure.
is that male male connectors?
Males at both ends of the cable.
Thanks Martin,
