Beovision 6-26 motorised stand
badgersurf
Posts 539
badgersurf Posted: Tue, Dec 17 2013 9:28 PM
I have just brought a motorised stand for my beovision 6-26, but I can not get the stand to work.
i unplugged the tv, left for a few minutes then connected the power then the stand, the connection does not show up in the menu. I have tried various other ways of setting it up from connecting the stand and then power on and off etc and nothing.
the BV 6 is type 9521 and the stand 1409111
Any ideas?
thanks
Toby
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Dec 17 2013 9:35 PM
It is possible to plug the din plug into the back of the set incorrectly. Remove the din plug and carefully check that it is plugged in correctly. Do this with the power of to the TV.
If that doesn't cure the problem....
There is a cable with a din plug that is connected inside the bottom of the pole. If this has come undone, the software in the TV will not detect the stand.
Unfortunately this will entail removing the television then detaching the pole from the base. You will then see the short lead from the base has to plug into the cable that goes up the pole.
Good luck
Opman
badgersurf
Posts 539
Just a follow up, the lead had come away at the bottom, so all working now.
Toby
Page 1 of 1 (3 items) | RSS
