Beomaster 8000 left channel dead
This post has 2 Replies | 2 Followers
aymeric
Leiden
Posts 158
aymeric Posted: Wed, Dec 18 2013 12:18 AM
I got a Beomaster 8000 with a dead left channel.
Done some testing:
- The big 10000 uF caps store 56V on both sides.
- The left idle current trimmer measures 6mV no matter how the trimmer is turned.
- The problem is with headphones and speakers
- The left amp heatsink is ice cold while the right one is lukewarm.
- The problem is with radio, and both tape inputs.
What should i check next?
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Dec 18 2013 6:15 AM
I'd say first things first, solder joints under the left amp PCB.
Jacques
aymeric
Leiden
Posts 158
aymeric replied on Wed, Dec 18 2013 5:36 PM
I've re attached the 2 cables to the big caps. They were hidden and taped off to prevent someone hurting.
When i powered the amp, one resistor just exploded even before i could change or measure anything. I will look at the schematics and measure the whole pcb now before i will power it on again.
Page 1 of 1 (3 items) | RSS
