HI there,
Need some help pls. Have a good working 4400 but have noticed that the treble from one side is less than the treble from the other if you listen carefully. Have done all the usual tests using the MONO button as well as swapping speakers around etc and it's definitely the amp side and not the speakers.
Anyone able to recommend someone who could fix/service the this for me near London please?
Thanks in advance.
Try contacting Tim Jarman via the Beocentral site - he is not great with email so may take a while!
Peter
Does he service other areas too?Or do you have any recommendations for Manchester?
Also seeing alot of repair service sites coming up like this repairer. These generally any good, that service multiple brands, or would you stick to a dedicated Bang & Olufsen dealer?
Try Rex Radio on 020 8969 1770
They have been selling and repairing B&O for years.
Regards Graham
Peter: Try contacting Tim Jarman via the Beocentral site - he is not great with email so may take a while!
Yes but he always answers!
Jacques
