How do I get access to this adjustment screw?
http://tinyurl.com/qj9cjsf
Lift off the long and apprx 3cm wide black plastic cover that runs above it, it goes almost all the widthof the Beogram, also above the carriage.It's just clicked into place.No tools required to remove the cover.
Thank you Martin. I didn´t know if I should dare to take that plastic part away.
Now I have adjusted all the lids.
