Which TV should I be buying - Advice needed
This post has 26 Replies | 1 Follower
londonguy
Posts 11
londonguy Posted: Mon, Dec 23 2013 11:48 AM
Hi All,
I have a Beovision 3 32" in my bedroom and would now like to use Apple TV etc and so am thinking about upgrading. I also have a Beosound 9000 and Beolab 9's connected to it, so this probably needs to be taken into consideration.
I'm after a TV with a picture better than my current. I was looking at either a Beovision 7 40 Mrk3/4 but also came across the Beoplay V1 and wondered what the general consensus is?
Is the Beoplay V1 any good or is it just a very entry level product? I know it doesn't have master link and this probably poses a problem when wanting to connect it to my equipment? Also, how does it compare to the Beovision 7 40" Mk3?
I apologise in advance for asking so many questions but any advice received would be appreciated.
Chris Townsend
Qatar
Posts 3,531
The picture will be much better than the 7-40 mk3.
It also includes Beosystem 4 I believe so quite a package, except cosmetically. Even though I loathe its looks, I'd buy one over a Mk3 7.
A Mk5/6 would be a different matter.
londonguy
Posts 11
londonguy replied on Mon, Dec 23 2013 12:24 PM
Hi Chris,
Thanks for the response. The question then becomes how would i connect the TV to the Beosound 9000?
londonguy
Posts 11
londonguy replied on Sat, Dec 28 2013 8:44 PM
Hi all,
I'm now now considering doing the inconceivable, I would never uttered these words years ago but can't find an alternate solution which seems worthy.
i came across a samsung f8000 46" TV and found the picture to be truly stunning, I compared it to the V1 and it blows the V1 away, therefore I've decided not to purchase the V1. Also, I don't think a second life beovision 7 mk3/4 would fare much better. The only problem is I have a beosound 9000, beolab 9000's and a beolab 2. If I bought the Samsung (dreaded thought), how would I connect it to the equipment?
Has anyone else moved away from B&O screens and lived a fulfilled life? Lol
londonguy
Posts 11
Hi all,
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Dec 28 2013 11:13 PM
check out my signature....
only thing I miss is Beo 4 control of all the equipment - which could be done with lintronic devices.
Ralf
symmes
Posts 247
symmes replied on Sun, Dec 29 2013 1:46 AM
londonguy:
Hi all,
How were you able to do that comparison....side-by-side?  And what do you mean by "blows it away"?
londonguy
Posts 11
londonguy replied on Sun, Dec 29 2013 8:31 AM
The comparison wasn't side by side but the picture on the Samsung was clearly sharper, more detailed and a lot more vibrant. I
Millemissen
Flensborg, Denmark
Posts 14,680
Which source was displayed?
Chris Townsend
Qatar
Posts 3,531
Compare them in store. I have never found the V1 picture anything other than nice or ordinary. I don't want it to be so, but find myself buying up Beovision 8's to fill the gap.
tobeyone
Posts 125
tobeyone replied on Sun, Dec 29 2013 8:52 AM
Well I have just done the opposite!!
Started out looking at cheaper alternatives to replace BV26-26, spent months looking around, and yesterday ordered a V1-32.
Have decided not to integrate it into my ML network but that in due course will get a matrix.
Mike
londonguy
Posts 11
londonguy replied on Sun, Dec 29 2013 12:31 PM
Is it easy to integrate the samsung with Murphy current setup with out having to buy a separate receiver?
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Dec 29 2013 12:55 PM
londonguy:
Two things, unless they were side by side on the same signal, it's hard to really tell. Plus, traditionally B&O sets haven't fared well in side by side demos because Beovisions are calibrated properly to be as film like as possible whereas most mass market sets are set to retina searing levels. Makes then pop when on the floor surrounded by other sets, makes them not a great set to watch a movie on. If you look at another brand get the remote and play with settings, odds are it'll be on Vivid or some such not Cinema.
FWIW I don't have a Beovision, but a Panasonic VT series 65 inch set that is just outstanding. Much cheaper than a Beovision 12 but not better really, about the same as they share glass. I'd probably give the nod to the Beovision 12 because of superior video processing, but it's incredibly close.
My video and audio systems are separate, B&O audio, other stuff for video.
Jeff
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Dec 29 2013 2:26 PM
I agree with Jeff. My better half once worked in a radio and TV department and all the TV's were invariably  set to run cartoon-like  DVD's. Presumably BluRay now fulfills the same role. Broadcast Channels were rarely shown, partly because of the inferior quality to DVD's and partly because of city centre reception problems.
There's mention of the BV8 above in this thread. I very nearly bought a BV8 as a link TV but was warned-off by Matt at Lifestyle who advised that it would disappoint if used to receive an analogue signal from a main TV elsewhere.
Graham
ouverture
London
Posts 263
ouverture replied on Sun, Dec 29 2013 4:29 PM
I agree with Jeff +1
my audio hi-fi is all B&O
my visual (in the lounge) is a Panasonic Plasma (which is what B&O used in many of their TV's) , Panasonic Blu-Ray, Virgin Tivo box for Cable TV and a big Yamaha DSP amp 7.1 - very happy !
very soon you will not be able to buy a big Plasma TV, they have been eclipsed by LCD, just when Panasonic were perfecting plasma screens that nearing perfection !
Mark
London
Posts 1,063
Mark replied on Sun, Dec 29 2013 4:58 PM
It still surprises me when you go to some of these electrical mega stores and have the ability to compare 20 - 30 tv sets and see how different all the pictures are, even when it is the same make and different screen sizes.
One of my woes, and many of you B&O holics will understand is the lack of thought with the foot/pedestal design or lack of.
Millemissen
Flensborg, Denmark
Posts 14,680
londonguy:
Note my signature!
If you buy a Samsung, you buy a tv.
If you buy a V1, you buy a BV.
It all depends on how much the Beo4 remotecontrolling, the integrated surround processor/preamp, the speakers (and the easy connection of your 9's), the 'auto-PUC-update-function' (for controlling external devices with the Beo4) etc, etc matters to you.
If you like a tv with a 'vibrant' display (at least in the shop) more than a BV, that has a picture one can look at for hours without getting tired, then go for a Samsung (or alike).
londonguy
Posts 11
londonguy replied on Sun, Dec 29 2013 7:02 PM
Hi Millemissen,
i don't think the Beo4 remote controlling is an issue anymore, the samsung has an infrared blaster to control the sky box, plus everything seems to be going the way of the iPad/tablet when it comes to controlling devices.
You're right I will loose the sound processor but as my bedroom is small I don't think I need surround sound. I will defineltey replace my main screen downstairs with a beovision 11 over the next few months but at the moment just want a temporary solution for the bedroom. Unfortunately I've not been swayed by the V1, on its looks which for me are ghastly and too industrial or on performance. Bang & Olufsen don't have anything else in the bedroom tv range to suite my needs.
I will investigate a second life beovision 7 40" and see if that plug the gap over the next few days. I hate to look at other brands but I guess it's no bad thing.
Millemissen
Flensborg, Denmark
Posts 14,680
Looking forward to hear about your experiences with the bedroom Samsung Smile
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Dec 29 2013 8:54 PM
I bought a second hand loewe individual selection (for its looks and sound) as a second tv set....
Ralf
PS: no B&O tv anymore, see my profile....
Amazone
Netherlands
Posts 187
Amazone replied on Sun, Dec 29 2013 9:27 PM
'Has anyone else moved away from B&O screens and lived a fulfilled life? Lol'
I did, some 3 years ago. Bought the most expensive samsung 46" I could get. Still glad I took that decision. Saved some 6000 Euro's compared to a 10-46, maybe more when you take the B&O built in HD tuner and stand into consideration. Those two options alone had almost the same price as my 8000-series Samsung. Next to this, the 10 was replaced by the 11, and MasterLink has been abandoned by B&O completely within a year after I made the decision. So I'm still really glad I didn't buy the 10-46 after all.
The Samsung is a very nice tv, has smart tv functions which became actually useful with the new youtube app, and with the Beo6 I can control it completely the same as it were a B&O. You can easily integrate it with B&O using a Cyp DAC and an Aux connection to Beosound or Sonos. But i agree, it will never become a B&O. Sometimes I think about upgrading to 55", and again, I'm comparing a Samsung with a B&O. Would really love to own a 11-55 but the price is just to high (for me any way).
regards,
Joost
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 29 2013 11:47 PM
vikinguk:
Graham
Interesting ... I had thought my inferior experiences with a BV8-32 slaved off a BV8-40 were a consequence of amateur wiring on my behalf !! It will be interesting to see how Chris fares with his newly acquired white BV8-32 ...
BeoNut since '75
Chris Townsend
Qatar
Posts 3,531
Leaving at 5am for a 3 hour drive. Worth it though :-)
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Dec 30 2013 7:37 AM
elephant:
I owned a BV8-32 for quite a while (two years?) as a slave TV. Yeah, it's ok. Picture was good, sound was good. Only problem I found with the BV8 was the lack of any glass in front of the LCD panel. Made it hard to clean, particularly when it's in the kitchen. The BV8 results in mixed feelings due to the design.
I now own a BV10-32 and haven't looked back - superb picture, audio, looks great, gets positive comments from everyone (literally, everyone) and is easy to keep clean.
Chris Townsend
Qatar
Posts 3,531
Well i have to say after owning the Beovision 8-32 for a day, it is one of the best B&O purchases i have ever made.
I hate to say it, the wife and i much prefer the stand alone sound of this 8, over my nearly new 11. Effortless warm bass, and listening to Michael Buble(wifes choice) the "orchestra pit" really works. A big band sound.
The feet that allow it to tilt are one of those simple, but brilliant solutions.
londonguy
Posts 11
londonguy replied on Tue, Dec 31 2013 12:22 PM
That's great Chris, the design of the 8 is more aesthetically pleasing to the eye than the V1 in my opinion.
After having a look at both the B&O and Samsung in John Lewis and also visiting a couple of dealers, I'm still not sure as I believe the pic on the Samsung to be far better. I am warming to the easy integration of the V1 and also B&O's new matrix style of sharing of source content idea.
I shall think about it for a few more days before making the leap as I really don't want to make the wrong decision.
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Dec 31 2013 2:25 PM
Recently, I decided with a heavy heart to retire my MX6000 to the bedroom and get a flat screen in the lounge.
I wanted to be able to view the interwebs service of our national broadcaster without any additional kit, and currently the only sure choice there is a Sony smart TV. The new BVs are out of my price range and I don't want to suffer something 2nd hand that is outdated from day 1 just because it is B&O.
Ended up with a 42W654. Built-in WiFi, quite stylish design with a thin brushed metal frame that fits great between my BL5000s, a very understated pedestal (yes, I hate those too in most Kikinoko flat screens!) that doubles as a wall mount once I decide on the final position. DVB-T2 tuner so I don't need to dump it as soon as the HD broadcasts finally arrive, and the picture engine is high-end for the price since they left out 3D and all such crap. And while waiting for that, truly brilliant SD picture! (there's a lot to configure and the shop settings might not be the best)
The drawbacks: very average internal sound - as expected, not an issue as I connected it to the BS6500 right away (the audio out is configurable for variable / fixed output with internal speakers on or off, quite exemplary). And obviously the plastic remote, which I will remedy with some programming as soon as I have time. Connectivity is limited with 2 x HDMI and only one USB port (which can be used for recording, a feature that works well). It could be a bit less picky on what file formats it plays, even though it runs Linux...
The smart features are OK and seem to be supported as well; in two months, the TV has downloaded at least three software updates and every time something got noticeably better. I'm very happy with it and would buy it again. Available also in 32" and 50" with slightly different features.
Can't argue against getting any of the new gen Beovisions if you can afford them, especially if you want integration. But if you're considering the <1000 euro TVs, do check out the Sony W6 as well.
--mika
Page 1 of 1 (27 items) | RSS
