Connected wii via phono sockets on side of bv5 but can't get it to connect .
With my old bv5 it automatically turned over when the wii was turned on.
Does it matter that my sky box is connected via hdmi .
help ASAP please as my son got new game and is driving me mad about playing it
cheers Colin
You have a BV5 HD?
So on 1 side the phono Camcord sockets and on the other side the DViI socket with digital phono socket?
Start with with the "TV"function and press "Camcord" on the Beo4. (List function on Beo4, needs to be added if it's not on the Beo4 list)
Thanks for the quick reply ,I don't know how to add camcorder to the beo 4 , instructions on this would be appreciated . Sorry I am not very clever with this sort of thing,
Press and hold Standby and after that List also. You will get "Add" on your Beo4 remote. Press List several times until "Camcord" turns up. Press Go to add the Camcord function.
Can't find camcord
I have a beo 4 navigator if that make a different
Camera?
Found and added camera but nothing happens when I hit go
Just by heart...
Enter setup menu, go to afaik remember to "Camera/Camcord", stay on it and press "Menu". You will see another screen with naming options for the camera input. But it can also count for staying on the "Socket" menu.
It's while standing on sockets press menu.
Still no luck
