Datalink cable for beomaster 5000 and CD50
gjaky
Posts 4
gjaky Posted: Tue, Apr 17 2012 9:56 PM
Hello,
My brother recently bought a bargain beomaster 5000+MCP+CD50 combo, but unfortunately he didn't get the interconnect cable for the cd player, I want to diy this cable but not sure about the pinout. I have the service manual for both beomaster and CD50 but it is a little bit confusig, regarding to the CD50 manual it uses a 8 pin DIN connector with only pin 8 (middle) earthed, but the beomaster manual shows only a 7 pin DIN connector with pin 2 (and case) grounded, but looking at the physical connector of the CD50 it looks like pin 8 is blank. Should I use pin 2 for ground there too?
Robert
Holland
Posts 204
Hi, see the photo from internet, hope this helps.
You only need the 7pin DIN. See here an example: http://www.soundsheavenly.co.uk/bando-datalink.jpg
The datalink is needed for (remote) signals from beomaster to CD50 and to beomaster again.
Regards, Robert
gjaky
Posts 4
gjaky replied on Wed, Apr 18 2012 8:26 AM
Thanks, great!
Yes we want this cable because of datalink, now the MCP does not command the CD at all, they are now just connected with RCA-RCA cable, but this is not how it should be.
Page 1 of 1 (3 items) | RSS
