OMG, isn´t this ever smart. ?
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Sun, Dec 29 2013 9:50 PM
Just came home with my first tangentiall BG, to my collection and was just about to connect it when I saw this. Surprise
Sure I have have done soldier on many different configurations of DIN connectors over the decades, from so many manufactorer, for so many purposes, Audio, DMX, Midi, special stearing devices, yawn, cant even remember.. but, but , but, never seen a soluction where you could unscrew the 6th and 7 th pin of a 7 pin DIN connector so it fit a 5 pin ?
Anyone knows if this was a unique B&O solution or a part of a DIN assembly standard. ?
My re-capped M75 are my precious diamonds.
Millemissen
Flensborg, Denmark
Posts 14,680
Can't answer your question, but it is/was used by B&O a lot.
No problem to unsrew the two pins - done that several times.
If you do, please keep them safe - in case you want to sell the BeoGram later on.
You could use this adapter, if you don't want to unsrew:
http://www.av-connection.dk/?Language=UK&PGr=4857&ML=328
http://en.wikipedia.org/wiki/DIN_connector
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Pins 6&7 are for BeoLink components.
If you wanted to connect this unit to an older B&O component without BeoLink (and which had only 5 sockets), then it was a smart and easy solution to remove only the 2 pins, without having to look for an adapter or install a new connector
Menahem
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jan 2 2014 9:01 PM
Sorry Menahem, Beolink is B&Os brand name for multiroom HiFi. It's a completely different thing.
Pins 6 and 7 in the DIN is for datalink, which is communication between individual components in your Beosystem.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Jan 2 2014 9:10 PM
I once bought a scrap Beogram CD3300 to get the precious screw-on pins... Actually only one is necessary, 7 for tape and 6 for phono if memory serves.
Well, I used several parts to maintain my CDX anyway! Stick out tongue
I do keep the hinges as a treasure...
Jacques
  • Filed under:
Stockholm
Posts 512
Thanks for reply
I know that pin 6 and 7 is for the data, which is quite logical considering whats on the other pins.
But maybe I didn´t express my question correctly, I was refering to the small screws. if this could be a B&O mechanical invention, or if anyone have seen this mechanical solution in other constructions ?
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Jan 3 2014 8:28 PM
Never seen it elsewhere so I think its B&O specific. But I do think its quite clever :-)
//Bo.
A long list...
the_o_master
Posts 856
BO:
Yes very clever. Unscrew 6 and 7 and you can use the newer Beogram (such a BG5005, 5500, 6500,7000, 9000...) with an older receiver or even non-B&O receiver. The only thing you will lose is the posibility to start the turntable with the remote control...
Vintage Bang & Olufsen
Page 1 of 1 (8 items) | RSS
