Hello everyone!
I have a Beogram 4000 at home. It has two cables (red and white plug). It is connected to a Behringer U-control UCA222. The USB plug is connected to a Beomaster 5
I know that I have to connect the Behringer Control with her USB on my PC but nothing is happening.
What I would like to do is to record my vinyls with it and put the songs on my PC so I can later put it in my Beomaster 5.
Can you help me? Thank you so much.
Your pc should recognice the Behringer USB device - please look in the (sound)settings/preferences for this.
And you need a software for recording the sound coming from the BG.
Record to WAV and convert to FLAC.
Don't forget to do some tagging - otherweise the BS5 won't show any titles/coverpics.
Greetings MM
How I should do this so my PC can recognise the Behringer? I put the USB from it to the PC and it just said it was ready to use... And where can I find the software? It was actually written on the cover of the Behringer that it was included but I cannot really find it.
I would google for the 'Behringer UCA222 plus software' - or just have a look at the homepage:
http://www.behringer.com/EN/Products/UCA222.aspx
