I have connected a HDR2 to a Beovision 3 28 with a scartcable and an antenna cable. But how to setup the Beovision so I can go the menu of the HDR2? It seems that the beovision does not see the HDR2. Does anybody have an idea?
you will have to configure the scartsocket to which the HDR2 is connected in the BV3 menu.
After assigning a BEO4-button to that input you should be able to start up the HDR2 - and to enter the menu.
Both userguides are avaible on the B&O homepage!
Greetings MM
I think from memory it's V.TAPE or V.MEM (?)
x:________________________
jldmelb:I think from memory it's V.TAPE or V.MEM (?) What time is it? Beotime!
What ever I try only the red dot from the HDR2 keeps burning. And on the BV3 I see a black screen with v.tape. Anyone a idea how to proceed?
Thanks kallasr. I have the normal user guide, but this does not help much either. The other problem is I am at my parents now where I try to install this. I will be leaving sunday as well. If you have more then the normal user instructions I will be interested though.
Very sorry, was just for HDR1....
I was able to retrieve the docs from here.
But I have read just use the V.TAPE or V.MEM socket of your TV and it should work out of the box.My guess: scart cable not fully wired...Sorry, I could not help any further.
Ralf
Thanks all got it working now.
I removed the mains cable instead of using the power off buton. Switch the scart port of the bv3 and turned the scart cable the other way arround. One of them or all should have done the trick.
