Is it possible to still get new tube for these televisions? Think mine has blown but would like to keep it.
Thanks. It is the later version on these sets
I'm not sure if the tubes are still available from the dealers so you would need to check, but I know some years ago the cost was upwards of 600GBP so depending on where you are in the world it may be cheaper to purchase another used Avant than to repair the one you have
