Beogram cd 50
This post has 81 Replies | 5 Followers
hbjorkas
Posts 7
hbjorkas replied on Fri, Dec 16 2016 10:18 PM
Hi
I just bought a CD50 with exactly the same issues as Matt. When I push the switch302 after the tray is closed, I can press play and the motor starts. It even did start to read the disc once (no sound though) and the timer was running. The OPU Unit seemed to move backwards as it should.
It seems like the issue now is that the OPU unit does´t move at all towards the switch302. I have few electrical skills, so I haven´t tried to use a ohmmeter or anything like that to try and find what´s wrong.
Any suggestions?
Best regards
thechosen2k
Posts 1
Hello,
i have the same Problem over here. Could it be a Voltage problem? Anyone fixed the strange motor behaving?`
Thank you!
Page 3 of 3 (82 items) < Previous 1 2 3 | RSS
