WiSA certified BeoLab Receiver 1
This post has 21 Replies | 2 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Thu, Jan 9 2014 8:48 AM
B&O mention the receiver now on the website and it was also mentioned in a pressrelese on the company website: http://www.bang-olufsen.com/en/the-company/press
Price for the receiver is quoted at: DKK 1.495 / €195 / $265 / £165. Should be available during February.
Has anyone seen the receiver? Assume it has to be very small and discrete to make sense.
/C
BO
Halmstad, Sweden
Posts 728
Like this.
//Bo.
A long list...
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Jan 9 2014 9:18 AM
BO:
Like this.
I see. Are they available in white? Downside is that two cords from mains are required.
BO
Halmstad, Sweden
Posts 728
No idea about the colours, but since the transmitter is in white one would assume that the receiver would be available in same colour choices.
//Bo.
A long list...
PhilLondon
London
Posts 3,637
BO:
Like this.
Is that the actual receiver?
Beoworld app with direct photo upload and emoticons.
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Jan 9 2014 10:12 AM
PhilLondon:
Yes.
//Bo.
A long list...
BeoMegaMan
Posts 601
It's black because it's assumed it will be on a floor or placed behind a speaker. You wouldn't want a white box behind the speaker as it would stand out more. Same thing with white on the floor in most scenarios.
Ah, you know... A little B&O here, a little there
symmes
Posts 247
symmes replied on Thu, Jan 9 2014 2:07 PM
Does Receiver 1 manage 1 speaker or 2?  Also, may we assume Receiver 1 could connect to a ML/MCL Converter or a small stereo amp to drive passive speakers?
vlohjr1
Posts 553
vlohjr1 replied on Thu, Jan 9 2014 3:00 PM
Any idea what the dimensions are thanks
Vince
BeoMegaMan
Posts 601
no specs' release just yet.
BeoMegaMan
Posts 601
symmes:
Good question. One would assume that since it is PL out, it would support two BL's provided you have a PL Y-Splitter or a BL with a PL IN/OUT. You should also be able to go to a ML/MCL kit with a fully mounted cable and it should work.
Millemissen
Flensborg, Denmark
Posts 14,680
I would not be so sure - I'd rather think that each loudspeaker has to be adressed individually.
In order to do the measurement right, they cant be placed too far from the speakers either.
But that is very important - do we need two of them (double the price), or do they come as a set?
BeoMegaMan
Posts 601
Millemissen:
I would not be so sure - I'd rather think that each Loudspeaker has to be adressed individually.
I think it would depend on the setup. One receiver would be needed if the BL's are close together and it's stereo. In retrospect you may need 2 receivers however, if you did surround as the transmitter is sending out the dedicated signal from the PL input on the transmitter per channel. Stereo is not the case.
vlohjr1
Posts 553
vlohjr1 replied on Thu, Jan 9 2014 5:33 PM
165 pounds a pair doesn't sound like bo prices!
Simonbeo
Posts 1,451
So it transmits across the room and not to another  room ?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jan 9 2014 6:41 PM
vlohjr1:
Vince
I you look at a standard network (or here powerlink) port, I'd say it is 9 cm x 9 cm and appr. 3 cm high...
Ralf
PhilLondon
London
Posts 3,637
I understand that the sender can be an "ugly" box, as it's connected to a TV and can therefore be hidden, but where can you hide this black box (and the power adapter) when you have let's say a Beolab 8000 or 6000?
This should have been a device designed a bit like a LC2, that you can leave on the floor. Also it should have an in-built power supply and a pass through so you can power the speakers through it.
BeoMegaMan
Posts 601
vlohjr1:
That would be per Receiver 1.
BeoMegaMan
Posts 601
Simonbeo:
Depends on where you put the Transmitter 1 :)
Simonbeo
Posts 1,451
And
PhilLondon
London
Posts 3,637
Simonbeo:
It could, but it's not meant to be used like that.
It's a wireless Powerlink, not a wireless Masterlink, which means you couldn't use a remote from the other room.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 10 2014 10:50 AM
PhilLondon:
Agree. Now I would need either need two mains cables from the nearest mains socket, and a very short PL cable from receiver to speaker (where I need to hide the receiver)
A PL cable and Mains cable from the nearest mains socket where I need to hide the receiver.
Not very convenient.
Page 1 of 1 (22 items) | RSS
