Buy a MLGW?
This post has 18 Replies | 3 Followers
Normann
Posts 277
Normann Posted: Fri, Jan 10 2014 9:46 AM
Hello.
I have been thinking for a while on buying a MLGW or not. My local dealer has given my a really good price, but i am not sure if this is the right product to buy these days?
So my question is what to do?
Someone who has this product and is it worth the amount of money?
I know there is a new Audio Product coming these spring, maybe wait and see?
MartinW
Posts 389
MartinW replied on Fri, Jan 10 2014 10:09 AM
It totally depends on what you were planning to do with MLGW. What did you want to benefit from by adding it to your system?
Normann
Posts 277
Normann replied on Fri, Jan 10 2014 11:23 AM
It's most for easier control thru the beolink app in each room, and after some time the lights and so on..
But mainly controlling the music, radio, spotify ...
MartinW
Posts 389
MartinW replied on Fri, Jan 10 2014 11:40 AM
Do you have a BeoSound 5?
Normann
Posts 277
Normann replied on Fri, Jan 10 2014 11:51 AM
Yes
BeoMegaMan
Posts 601
While the MLGW is expensive, I have never installed one and had a customer say I wished I hadn't done that. I think you find that you can enjoy your system on a whole new level with the MLGW.
Ah, you know... A little B&O here, a little there
Normann
Posts 277
Normann replied on Fri, Jan 10 2014 1:53 PM
What do you mean by this? Did your customer regret buying Mlgw? Or is it a good thing to do:)
Rivenflush
Gothenburg
Posts 333
BeoMegaMan was basically stating that all his customers have loved it and cannot imagine how they could cope with life before MLGW Smile
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
olvisab
Posts 1,391
olvisab replied on Fri, Jan 10 2014 5:52 PM
BeoMegaMan:
Since I have mine, I absolutely think the same thing.
If you own already a bm5, linked rooms with av or audio, it is really interesting
But the most interesting thing is to be able to control your light, camera with the same app.
It is not easy for a newbie to program it especially if you don't have any experience in computer and programming.
If you think you are not able to program it, you should rather use separate app from control4, lutron ...
I would say that buying a b&o tv is a new level , by adding a MLGW it is 10 levels above at least.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Normann
Posts 277
Normann replied on Fri, Jan 10 2014 9:11 PM
olvisab:
BeoMegaMan:
I was told that one technician from the shop could install it for me.. But can i build out one room after another in my house? Or is it difficoult for me to do this by my self?
olvisab
Posts 1,391
olvisab replied on Fri, Jan 10 2014 10:10 PM
You have to create each room in the soft and add each b&o product inside each room.
Then after you can create button in order to execute specific tasks (called macros)
The tasks called by one button can control the av equipment and/or lights
This is not complicated when you have seen an example.
So yes, you will be able to add other rooms and modify your current installations if you look at the way your technician has programmed it.
You just have to use the ip address of the Mlgw in order to use the setup software.
If you plan to control lights or domotic tasks you will need other skills.
The Mlgw is compatible with Lutron, clipsaĺ, knx or control4 with the recluse av driver but you have to call a specialist in order to make the installation.
In the next months i will have more information about the cost of the recluse av driver and the first control4 equipement needed for the beginning.(wireless with zigbee)
Normann
Posts 277
Normann replied on Sat, Jan 11 2014 9:04 AM
Thank you Smile
pf85
Posts 284
pf85 replied on Sat, Jan 11 2014 9:33 AM
Excellent thread. I am  mulling exactly the same question as Normann with a similar extensive setup. Just not sure if I should wait for the specs of the announced BeoMusic App.
olvisab
Posts 1,391
olvisab replied on Sat, Jan 11 2014 10:36 AM
Hi
Where are you living ?
Some Lutron products are ony available in united states for the moment.
The choice will depend on your location and the ability to find a good professional in your area.
For the moment, control4 seems to be the most affordable and more opened system (gateway to other av brands) available. The question is : is it possible to use it in your actual house without spending ten thousands of euros for just controlling some lights at the beginning.
The wireless technologies (zigbee and z-wave) will helps.
I will let you know as soon as I have more information.
olvisab
Posts 1,391
olvisab replied on Sat, Jan 11 2014 10:41 AM
Whatever the specs of the new app, you will always need a hardware gateway between the b&o system and your lights system.
A sony receiver is available in the united states with a control4 controller built in.
Unless b&o decide to do the same with his new beosound, you will always need a kind of Mlgw
The mlgw let you the choice (lutro, control4, clipsal, legrand btcino....).
pf85
Posts 284
pf85 replied on Sat, Jan 11 2014 11:40 AM
olvisab:
 thanks for your answer - inching closer to an affirmative MLGW decision.
northswede
Stockholm - Sweden
Posts 43
I'm also thinking of purchasing an used MLGW to my system for integration to a home automation system.
Is there any possibility to add 3:rd party support for example z-wave controllers (In my case Fibaro Home Control)?
As I understand it the MLGW can be accessed though HTTP PUT and GET commands?
Seanie_230
UK
Posts 2,278
Hello everyone
i am in the same place, I think I would like a MLGW but cannot decide between ML and Beolink gateway.
i can say that I spent thousands of pounds on control 4 and setup. I very quickly decided I did not like the interface or feel of it.
I very quickly moved back to B&O. I had multi room audio and loads of stuff but it just felt second best.
i have an ilight light unit in my lounge that responds to the beo4 I do have the serial interface can the MLGW or Beolink gateway send bespoke serial commands or can it communicate with ilight?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Thu, Jan 8 2015 9:45 PM
Seanie_230:
Hello everyone
hi seanie!
if the price is okay buy a used mlgw. otherwise a blgw.
you can connect nearly all the the rs232 of the mlgw. (only one!) the blgw has more rs232 connectors (if you need)
you can control not supported devices via custom strings. i control the lintronic TT455-RT-238 via strings over rs232 - so i can control with the beolink app all other devices via ir. or the TT455-RT-238 send ir to the jbmedia lightmanager  -  this is a cheap way to control the light. and so on.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Page 1 of 1 (19 items) | RSS
