Radio2? - did not notice that on my V1.
And I don't have that in the list of my Beo4 (SW8.00) either.
Millemissen:Radio2? - did not notice that on my V1. And I don't have that in the list of my Beo4 (SW8.00) either. MM There is a tv - and there is a BV.
MartinW:You can use V.Aux2 no problem. It will turn the screen on though, as it is a video command and Spotify is a video source. Just do P.Mute afterwards. You'll need the screen on to pick some music anyway, it won't automatically start playing anything.
