Manufactorers of Tengential system,
This post has 10 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Mon, Jan 13 2014 1:02 PM
To my memory it was mainly B&O and Studer/Revox that produced these kind of record decks.
I posed earlier a post about some kind of BG4000 copy made in the former Soviet union.
A friend of mine showed on his facebook a Fisher , 80th-style deck that also was tantgential.
That brought me to this question, which brands did tangetial system ?
Anyone with more memories ?
Christian
My re-capped M75 are my precious diamonds.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jan 13 2014 1:32 PM
In the 80s, quite a few Japanese makes produced tangential decks - Technics produced some very neat decks the size of an LP sleeve with the arm in the lid, Mitsibushi produced a vertical deck, as did Sharp. The Technics decks were well liked in reviews and well built.
One of the other vertical decks had two arms, one for each side so you didn't have to turn the record over!!
Peter
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Jan 13 2014 2:34 PM
Mitsubishi made a vertical version and looking quickly on ebay.de there are quite a few around from different makers.
http://www.ebay.de/sch/HeimAudio-HiFi-/14969/i.html?_from=R40&_nkw=tangential+plattenspieler&rt=nc&LH_PrefLoc=2
There are some very expensive tangential arm assemblies only being produced which a Google search will show.
If you take a peek at these images then there are several B&O tangentials and also some monstrosities (including a bizarre Thorens 124 set-up).
https://www.google.co.uk/search?q=tangential+arm+turntable&tbm=isch&tbo=u&source=univ&sa=X&ei=xPfTUp-HAu_60gWD3YHgAg&ved=0CC0QsAQ&biw=1680&bih=934
Some great engineering though - goodness only knows what some of them sound like!
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Jan 13 2014 2:35 PM
My favourite is the Pioneer PL-L1000.
It was Pierre Clément, a Frenchman engineer in audio, who patented the system as found in Beograms, in the mid-sixties!
http://www.proactif.com/rb/platine.htm
Jacques
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Jan 13 2014 4:40 PM
Back in the 70's Harman Kardon made the ST-7 and 8, I think that was the nomenclature, table that used the Rabco tangential tracking arm. We sold these, they were a bear to keep working. The guts were a shaft that rotated, and a rubber wheel attached to the arm carriage that as the arm moved inwards tracking the groove would turn the wheel from straight ahead, that is 90 deg from the shaft, and that would create a force that would cause the arm to move back straight ahead aligned with the groove. Man when these got out of alignment they got weird. You'd see them tracking the album in all different angles.
http://www.thevintageknob.org/harman_kardon-ST-7.html
When setup well they worked quite well though, and you could choose the cartridge you wanted.
Jeff
Stockholm
Posts 512
Thanks for many good answers, Smile, yes now i remember many of the the small technics.
The stand up ugle sharp intergrated versions aso.
Jacquesboo
Posts 171
Sony also did some that looks like video recorders (with ejectable platter) ! That could have been an idea for a B&O pizzabox (5000;5500;6500;7000) turntable no ?
SONY : PS FL7 : http://www.youtube.com/watch?v=3ylpu7PoCzw
image from : vinylengine.com
Orava
Finland
Posts 991
Orava replied on Tue, Jan 14 2014 10:51 AM
Jacquesboo:
Almost like Marantz I had.
Orava
Finland
Posts 991
Orava replied on Tue, Jan 14 2014 10:55 AM
Also Luxman, for example
Marantz...
Yamaha...
Stockholm
Posts 512
I check regulary second hand market on adds, if we dont include B&O, tangetial records decks seems to be incredible rare as second hands.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Jan 14 2014 4:15 PM
There was one, a Panasonic I think, that could be wall mounted and had the option of a pair of brackets to sit it on the shelf raised up at about a 45 deg angle, that actually made it into the Museum of Modern Art.
Found it:
Technics SL-10
Jeff
Page 1 of 1 (11 items) | RSS
